 - Sep 2, 2007
Specs.
0.100 CPM M4 @ 64 HRC
Overall 8.1"
Blade 3.75"
Height 1.25"
0.008 behind the edge with about 17 DPS
Handle Black Cherry G-10 with aluminum pins and tube
Kydex sheath
The blade came hair popping sharp off chris's work bench and had a fine edge finish.
I tested this knife on 1/2 inch manila rope and sliced from the back towards the front using about 2.5 inches of blade. The blade was tested by slicing paper about every 30 cuts.
This is after 120 cuts on the rope. It still sliced paper clean and easy.
After 320 cuts it didn't slice paper as cleanly, but that's to be expected. With good blade geometry and cutting performance it was still popping through the rope.
I ran out of rope at this point but it did 390 cuts. It still had a great working edge but it would snag while slicing paper. I then moved to cardboard and it sliced through effortlessly.
The knife performed very well in this abrasive type cutting. I used my M4 Spyderco Gayle bradley as a comparison, and due to improved blade geometry and 2 points in hardness this Big Chris cut longer . I would recommend a Big Chris knife to anyone looking for a great high performance blade at a fair price!
Thanks Chris.
