Chronovore
- Aug 29, 2019
There is no lock stick, rock, or play.
When you check for lock rock, how much force do you apply? Also, are you checking from both points of lock-up?
If you have a firm grip on the handle and a firm pinch on the spine, and you try to rock it, I'm very curious as to whether the point of lock-up drifts.
As far as slow versus fast, lots of modern folders (especially those running on bearings) are meant to be snapped or flicked open fast. Of course, there is an invisible assumption of tolerances there. For instance, if you are winding up and putting a bunch of wrist into it, that could be questionable. Ideally, it wouldn't be. I'm just saying it could be. I feel like the proper use of a good modern folder (the kind on bearings anyway) is snapping or flicking it open with just the thumb on the stud, just the finger on the flipper tab, etc.
The theory about stop-pin bounce sounds plausible but I've had and tinkered with a large number of fast-opening modern folders and I don't ever recall seeing this. I mean, it's possible that I've never noticed it, and I almost never slow-roll something that I can flick. Still, I just tested like ten random knives ranging from $25 to $500 and none of them did this.
