big question from a newbie
Yes, although it would be good if you roughed up the surface first. Also, don't use regular glue, use some epoxy such as gflex.
The finish of the cerakote will also play a roll into how well it will hold... If it's matte then it will hold much better than satin.
Can micarta scales be g-flex glued on to cerakoted metal? Wanted to see if anyone had an answer before i go wasting materials and time running a test.
Thanks for the response. Its my 1st time using cerakote, and want to waste as little as possible.
