Bigfoot Hiking Stick, Walking Staff
I bought 2 of these a couple of weeks ago and thought I let anyone interested know. These are a neat product with the contents inside the handle. I would have prefered a more durable handle out of fiberglass or an unbreakable polymer, but this is still a nice product which is stong enough to be used as a self defense weapon if needed. The weight and feel of the staff is comfortable and with the bright color you won't lose it and you can add more preference items to the list of things inside.
I got this info and pics off the ebay site.
Uses and Contents: This hiking stick contains a basic survival kit. The hiking stick is made from lightweight thin walled steel tube. The 1-¼ inch diameter tube is sprayed with a scratch resistant bright orange textured powder coat finish. The length of this stick is 63 inches. The handle grip is designed to be removable for access to the tubes but will remain in tact during use. The bottom of the stick is equipped with a wear resistant crutch tip design that deters skidding. The contents are stored inside four compartmentalized tubes (fifth tube provided for additional storage space). The acrylic plastic tubes are clear so the contents can be viewed. Everything is packed in a manner so that the contents are accessible when needed. The contents are well protected against moisture and wear. The first aid kit contains all of the items normally found in a first aid kit, which would address most minor injuries and discomfort. The space blanket (emergency blanket) is ideal for outdoor safety. This item can prevent hypothermia by reflecting and retaining body heat. The blanket size is: 51 x 71 inches. The knife is a high quality utility knife that can be used for cutting small limbs for fire or can be used for self-defense against animals (predators). The signal mirror is laser cut plastic signal reflector mirror that can be used to attract search aircrafts. The chemical light stick is a single use 12-hour light stick that can be seen for great distances and is of the same grade as those used by military forces and rescue units. The quality Scripto lighter is useful for starting signal fires or heating fires. The flashlight is machined aluminum with a krypton bulb, and will provide a minimum of 24 hours continuous light. The whistle is extremely usefully in trying to attract other hikers or searchers and can be heard for hundreds of yards. Everything in this tube is top grade. This is stuff you can really use. This is something that is really going to help you. If lost, your chances of being rescued will be greatly improved. The hiking stick is shipped in a thick cardboard tube which is great for storing the stick in when your not using it.
THIS STICK CAN BE TRIMMED TO ANY DESIRED LENGTH BY CAREFULLY CUTTING IT WITH A HACKSAW. JUST REMEMBER, THE CONTENTS ARE STORED INSIDE THE STICK SO YOU WILL BE SACRIFICING SOME OF THE STORAGE CAPACITY. PLAN IT OUT BEFORE YOU MAKE ANY CUTS. IF YOU WANT A SHORTER STICK, I OFFER A 52" STICK FOR THE SAME PRICE IN MY OTHER LISTINGS. THE 52" CAN ALSO BE TRIMMED. I DON'T RECOMMEND EVERYONE SHOULD DO THIS BUT I TRIMMED MINE WITHOUT ANY PROBLEMS SO I KNOW IT CAN BE DONE.
Overview of all contents inside compartmentalized tubing:
Space Blanket (Emergency Blanket)
Chemical Light stick (lasts 12 hour)
Nylon String
Signal Mirror
Lighter
Knife (serrated cutting edge 25 yr. warranty)
Whistle
Aluminum Flashlight (uses 2 - AA alkaline batteries)
Non-aspirin pain reliever (2 single dose packs 500 mg)
Ibuprofen tablets - 2 single dose packs 400 mg
Triple antibiotic ointment - 2 single use packs
Cleansing Towelettes - 2 single use packs
Antiseptic Towelettes - 2 single use packs
Bandages – 2 each of the following sizes: ¾ x 3 inch, 1 x 3 inch, 2 x 4 inch.
Good idea, how much did it cost? Give us a review of the staff and the gear inside. The knife looks like a small kitchen knife, would you want to upgrade it?
The price for one was $19.25 + shipping. You can find them on ebay under BIGFOOT HIKING STICK SASQUATCH WALKING STAFF BIG FOOT Additional shipping was $1.50 so I bought two.
I would definetily replace the knife, and flashlight with a LED, or just add to them. The rest of the stuff is very usable. They give you an extra tube for adding more if you want.
It's a neat and usable back-up or addition for your PSK.
