The table is off a miter saw table. The kind with the wheels that breaks down and rolls around the job. It served as an extension to the saw table itself.
The hardest part was getting it in alignment with the belt grinder itself. I just used a square and came off the machine base. The square tubing had to be level also. It slides quite smoothly and adjust to the desired position fairly fast.
If you go to build it give me a yell if you need direction. Its a pretty easy build though.
