- Aug 18, 2019
The safest way imho to pocket carry a pocket knife is using the clip to align the blade edge against a pocket seam. Further on the safety seam, I prefer tip down since if the blade partially opens it can't catch on the pocket and open further during extraction.
I have never liked pocket clip carry, however.
I used to carry my pocket knife loose in my front pocket until I had an accidental partial opening inside my pocket. It was an AFCK with a big round hole and my handkerchief wedged partially into the hole and pulled the blade slightly out of the handle. Since the return spring (lockback) was so weak, the blade didn't snap itself back in. I got a slight finger poke - I got away easy.
Since then I've looked for ways to more safely pocket carry my rotation of pocket knifes.
So far I've only found two ways:
1. An actual sheath, thin nylon, covering the pocket knife in the pocket. REI sells a couple of sizes. However is you don't cut off the Velcro flap, the knife is no longer very available; and even if you cut off the Velcro flap, these nylon sheaths are usually so snug they don't slide off the pocket knive.
2. My current preferred sheath: a racing bike innertube, cut to length, stapled at bottom. In my pocket the knive is positioned upright, in the innertube which covers have the handle, and held in place by a combination of compact wallet with handkerchief over wallet and pocket knife.
I just pull the pocket knife up and out of the innertube sheath; the innertube sheath remains in pocket.
I still think lockbacks with enough tension to snap the blade back into the handle when opened up to 1/2 an inch are the safest. There's generally not enough movement or room in my front pants pockets to allow an accidental opening more than that. Also I haven't had a problem with thumbstuds; it's those large opening holes that catch things (keys being the worst).
That having been said, if you get stuck with lemons, make lemonade. The Ernie Emerson Wave opener is a good example. Emerson was apparently experimenting with a prong to "catch" an opponents blade in close quarters combat when his prototype customers reported back to him that the prong was catching on their pockets and whipping the blade open during extraction - an incidental "defect" that quickly became a feature. The only two requirements? Tip up carry and edge against pocket seam carry - using the feature doesn't require a pocket clip, but for safety the pocket clip is essential, since the Emersons are one line of knives DESIGNED to catch and open.
Oh. Yeah. I like Emersons so I work around my dislike of pocket clip carry by - that's right - carrying an Emerson tip down in my innertube half-sheath. Afterall, tip down the Wave prong won't accidentally catch on my pocket, and once extracted there's always the opening disk as an alternative. Well...there's another use for the Wave prong, but I'll post separately.
