Bird and Trout Frame Handle WIP
HSC ///
In August I visited James Rodebaugh MS for a class on handles and guards.
The final project was a stag frame handle. The most complex for me.
for 2 months since, I have not made a knife as I reflected on whether or not I wanted to continue knifemaking and if this craft was even right for me.
A few days ago I decided I was going to at least give this frame handle a go
And so here this is my first attempt. Also first try with parkerizing and working with ironwood burl (which was not easy).
It needs a bit more polishing up but I had to get over the Plaza Cutlery knife show :-)
Bird and trout 3 piece frame handle with parkerized W1 and ironwood burl with silicon bronze ferrule and frame . Pattern and design by James Rodebaugh MS.
This hidden tang did not need a frame handle but it was more an exercise in practicing before I move to stag
Comments and criticism welcome.
Nothing revolutionary here but there are things to pay attention to in order to get the best fit.
I'll add pics and commentary
start with a good forging, James forge to a blueprint
grind the blade, get the ricasso flat and parallel within .002 using a disc sander and patience.
design the layout - looks I like I had a little too much whiskey given the line tracing!
set the shoulders using a carbide file guide, next time I'll do this pre-HT
file in the plunge line, use the Nicholson files made in the usa, not the new made in Mexico ones, my suggestion
temper the tang so I can drill a hole thru it - also will do before HT next time
parkerize the blade
layout the frame to see what's going on
mill the ferrule
check the guard fit
I press fit the ferrule, cold
check the fit at 10 x magnification, if it looks good here, it will look great the the naked eye
profile the ferrule
lightly scribe the centerline
check alignment
at this point my procedure is 30 steps to completion
this will be condensed and I'll skip documenting some steps
profile frame
file flat the end of the frame
check how does it look?
layout and drill holes
layout frame on scales
drill into scales
and then my bandsaw blade broke and the 5 min cutting out of the frame became a much longer ordeal. In retrospect I should have just went and got a replacement blade..
fit the end of the scales flush to the frame
check the fit assembly
at some point here I had to chisel out the relief for the tang in both scale halves
a dovetail undercut would be ideal
profile the scales
check how does it fit up?
and to prove I went to the show :-)
Kansei Matsuno friction folder, D2 with ironwood
Looks beautiful Harbeer. I do hope you stick with Knife Making, you certainly have a talent for it.
Stay in touch,
Ben Greenberg
Greenberg Woods
You have a very good eye for the flow and a talent in knifemaking!! Don't give up!!
Thank you for the WIP :thumbup:
thank you all for the nice comments
I'll do one more than be ready to try some stag.
When I was a collector I bought 2 WD Pease knives and he is a master with his handle materials.
Fortunately yesterday he was at the Plaza Cutlery show and I made him teach me how to look for the best stag rolls. :-)
