I got a BK-7 a little while back. I am going to use this thread to post the mods as I do them.
First thing is to remove the paint. I didn't really care much for the black paint so I got an old can of stripper out and introduced it to the 7. They intermingled and magic happened. Here are the results.
First I electro etched the name and model of the knife. I am guessing that it was just laser etched through the paint and not really into the metal all that much. I did a fairly deep etch.
Then I removed the handle scales and covered the knife in the stripper. I was surprised at how the paint or whatever it is started popping off the blade.
After a bit of scraping with a putty knife and rubbing it well with steel wool I ended up with this.
Here you can see how the electro etch worked out.
And last but not least the finished knife.
Overall I am happy with the way it turned out. I was a little surprised to find such a roughly finished knife under all that paint. All the grind marks are there and the mill finish is still present on the flats. It is not a biggy though as I really like this knife and do not intend it to be anything other than a hard use knife.
Sometime if I am motivated I will sand it out and put a rust finish on it.
Greebe
Greebe
