Cliff Stamp
BANNED
- Oct 5, 1998
Frank :
It depends on the vector of the applied load, it is dimension specific. It is far harder to pry with a knife for example in the edge to spine plane than though it, this is trivial to demonstrate with any non-square object. This would not be the case if the bend strength was linear in all dimentions as the cross section is equal in all orientations. The strength is linear only in the perpencidular planes because the slip plane deformation requirement doesn't change with thickness in those dimensions.
[thin blade]
Yes, which does help you out some, and which is why as noted in the above, you can get those large bends with tapered blades. However you still have to be careful of the elastic limit. There is however a rather significant gain in knife durability from lower cross section which can counteract the strength loss significantly. If the user has enough skill, the applied loads will be lower given specific task [outside of direct prying of course] as the knife is more efficient. In that case the durability doesn't 't fall off as fast as the raw strength loss. This only holds for overbuilt knives though [based on skill level] and thus there is a lower limit.
In those noted vectors, again it has to do with the nonlinear strength in those dimensions.
-Cliff
When you double the thickness of a knife blade, you double the amount of material and the strength as well.
[thin blade]
... it will deflect further with out reaching it~Rs elastic limit
Are you saying that prying with the edge or tip is not likely to cause damage?
-Cliff
