BK16 Sheath (DIY)
:jaded::jaded::emot-yarr::uncomfortableness:
It's referred to as a "dado" when closed on both sides of the channel and a "rabbet" when on the edge - like yours.
Cool process pics - thanks! So...then you just heat the kydex and roll it around the jig...? Man, I made a jig way more complicated than that! It hardly even works' tho - next time I'm making one like yours! :rolleyes::thumbup:
I use a heat gun with an attachment that narrows the field and start with the hook end. I heat just that part until it's floppy, slide it into the channel (open side down) and curve it over the edge, then press with my gloved hands. I use a firm surface like the concrete floor or the table saw. When it's cool enough, I then heat up the curve for the top, flip the entire apparatus over and press it with my hands. Once that's done, I trim it, even up the edges, and round them with a belt sander.
Thanks for the follow up. I was thinking maybe you did the whole thing in one go... seriously makes my jig look like a Rube Goldberg contraption.... but then I secretly enjoy making things more complicated than need be.... some of the time. Thanks again for posting the pics and the process.
I've tried to do it all at once, that way leads to cursing and many reheatings.
Especially using a heat gun - I'm trying to make some small sheaths and just getting that stuff up to an even temperature long enough to get it in my press is driving me nuts - I gotta get to the Savers and get a used toaster oven.
On a completely random yet related track, I did some work at a place that manufactured acrylic (ie-heat molded plastic) "water pipes" and they were using a gas range oven hooked up to a propane tank to heat the acrylic tubes, which were put into an aluminum mold and given a shot of compressed air to expand them in the molds. Pretty cool watching that process.
