Update as promised:
My replacement BK29 was delivered while we were away dealing with a tragic, senseless death in the family. It was here when we got home this past Tuesday night (10/24/2017), but I don't know when it was actually delivered. I received no notice of shipment. It simply showed up. I am still heartbroken over our loss, so pictures will have to wait.
Grind (spine): The grind on the spine is much better than the one I sent back. It is just about perfect to the eye.
Grind (edge): The straight part of the edge is very slightly recurved. A critical eye can see it, but it appears to be only 0.011 at the "worst" part, measured with a straight edge and feeler gauges. At that point, you have to check how straight the reference straight edge (blade of a combination square) truly is. I think it might be pretty difficult to get the straight parts of a knife edge truly straight in the production process.
Profile: Referring to this thread https://www.bladeforums.com/threads/20-29-greatness.1483074/
I measured a bit less than 1-3/4 at the spot where 91bravo measured a bit less than 1-13/16
I measured a bit more than 2-1/8 at the spot where 91bravo measured about 2-1/8
Length: Measuring the blade length from the end of the handle, I am a bit less than 10-1/2. It is supposed to be 10-5/8. I am the same amount short in overall length spec. I assume the blanks are die cut, wire EDM cut, or some other computer controlled process, so I suspect they are all the same. I cannot imagine losing a bit more than an 1/8" to grinding so I wonder if the 10-5/8 is an accurate spec? All my other KABAR knives are right on if not a bit over. I am curious about this and would appreciate any feedback anyone might have.
A note about packing: KABAR really needs to pack a bit better. The shipping companies must really sling stuff around. My point is very slightly dulled and you can see where the big, heavy BK29 came through the KABAR box at least three times. Fortunately, it made it out the side of the cardboard shipping box only once. If KABAR would only ball up some of the brown paper they use and put it between the ends of the knife boxes and the shipping box, before they tape up the shipping box, I bet they would stop about 99% of this nonsense. As it is, they seem to put a lot of paper on top of the knife boxes before they tape up the shipping box, but none on the ends. This really matters with heavy knives like the BK29. Someone should clue KABAR in to this small change in packing. I am sure this would do a lot of good. I wish this had not happened, but the point is only very slightly dulled. My experience is that many knives that actually get used often end up losing that perfect "pin point" anyway.
Sorry about no pictures, but I am still pretty torn up about losing a young nephew for no good reason.
Best,
Gun Doc
Best,
Gun Doc
