- Dec 21, 2006
Wow, this was a FUN build! I received an AG Russell catalog not too long ago, and inside was one heck of a knife...the "Sandbox Bowie". The inspiration for this knife definitely came from their design, but with my own take on it. The swedge isn't really all that sharp, but it is apexed. It wouldn't take much effort to sharpen it completely if you so desired, but the swedge does sport a "mirror" finish as is. Grind lines on the flats run lengthwise, and for a nice contrast the grind lines on the bevel run vertically. I like G10, hate working with the stuff, but it is extremely durable material. It was interesting trying to keep the "grain" of the G10 looking good when profiling the handle. It has G10 liners as well, an inner black, and middle white. The "pins" are actually stainless steel tubing, and they are chamfered. You can use them to lash the knife onto the end of a pole to make a spear. Because you never know when you need to make a spear! You may just be dropped into the African plains with a camera crew following you around, so you need a knife/spear so you can look cool! The steel is 52100 from Alpha Knife Supply, and was normalized and thermal cycled for fine grain and toughness. It has a thinner edge (the edge just did barely reflect light before sharpening) than most Bowie knives, but the heat treat is spot on. Now for a few specs, and then the eye candy...
Now "axeing" just SOLD, and accompanying it will be a sweet Kydex sheath with belt clip. You can disassemble my Kydex sheaths to clean them, and even move the belt clip to different positions. And, as always, I will ship it to free anywhere in the United States. (No animals were harmed during the making of this knife
Paypal is preferred, but I'll take a check if you don't mind waiting for it to clear before sending. Paypal is samuraistuart@yahoo.com
Thank you very much!
Stuart Davenport Knives
San Antonio, TX
OAL: 11.75" (29.8cm)
Blade: 6.5" (16.5cm) (measured from handle front)
Edge: 6" (15.2cm)
Thickness: .173" (4.4mm)
Edge: ~30° total, .010" at edge shoulder, 8 micron (2K Aotoshi)
Balance point is 10mm behind the handle front
Edge: 6" (15.2cm)
San Antonio, TX
