I'd heard a lot about the Edgepro especially but hadn't researched it enough. I put that at the top of the list.
This VG-10 is taking forever to reprofile, it's almost done though finally. I will be buying an Edgepro before I do another one lol.
If you are looking at the EdgePro, I think that you should look at the new Wicked Edge stuff - if nothing else, just in the spirit of being a good consumer. While you can certainly drop some serious coin on the WE system, they do have a new entry level system called the Go - they are taking preorders, and it's amazingly affordable. I started sharpening some 40 years ago, on Arkansas stones, and last year I moved into a SharpMaker, then the WorkSharp Ken Onion with blade grinding attachment, and a couple weeks ago converted to the Wicked Edge.
Each system change has been incredibly worthwhile in terms of features, use, and work product output - while freehand on Arkansas stones was kinda-sorta working, the new steels were increasingly difficult to sharpen, just too hard. The SharpMaker, with the CBN coarse rods, made sharpening at least possible, and I got OK results.
The Wicked Edge is another ballgame entirely. It was easier to learn, by far, than the SharpMaker. It produces edges like I have never seen before: incredibly sharp, incredibly refined, and I have direct control over every part of the process.
The WorkSharp, followed up with stropping, did pretty darned good. But you have to (a) have the balls to essentially hold your good blades freehand against a powered belt, and things (both good and bad) happen quickly (b) learn workarounds for things that can destroy your blade in a couple breaths. I will still use the WorkSharp for some reprofiles, and also for a quick sharpening of a lower-end kitchen or utility knife.
In fact, thinking about this while typing, I'd say that if your only concern is the time it takes to reprofile, seriously consider the WorkSharp.
Good luck with whatever path you choose, and let us know how it turns out.
