The way I see blade centering, it falls under the manufacturers terms of "Craftsmanship". If a folder is built and assembled correctly, it should have a centered blade. That means that the craftsmanship is high.Just like anything else, you expect symmetry when you buy pants (both legs the same length, when you buy shoes, both have the same stitching and fit your feet correctly), when you buy a table (you want all 4 legs to be the same length so it won't wobble). Most manufacturers warranty their products against defects in materials and craftsmanship. More than one manufacturer has described craftsmanship as the way the item is assembled. A wonky blade isn't good IMO.
I'm insane about it...just part of pride of ownership I suppose, as well as a symbol of attention to detail like Rev mentioned. I'll tighten or loosen pivots, switch washer sides...hell, I've even bent a frame a little to get a centered blade. Nothing like seeing it go right down the middle, and on some pieces almost required given how tight a blade's "bed" between the scales may be.
I'm adamant about centered blades in the knives I buy.
I see what you did there.![]()
The blade being off center can hurt resale. So, if I buy one off center I would look for a discount.
