- Mar 5, 2007
Hello guys this is my way to etch a blade.
And if it works perfectly on a very nice steel I suppose it works perfectly for every kinda of work also for stainless.
My inspiration was yesterday when I disgorged my bath tub and using the liquid acid it stained all aruond my stainless ware...
So that's my way: it is simple, very effective and gives quite nice results with a minimum effort. If I do this results I think that every one can give the same results easily.
Please use every precautions since I'm using diluted acid, at least wear safety goggles.
Here it is my very complex electric equipment
A 9v battery, two crocs clips and some wire taken from loudspeakers. All fo this was securely taped so i don't need to soldier at all.
Since I'm a pro designer I have easy access on plotters and cutted adhesives. So first I designed with a vector software my logo that I use also for leather ware and I had to send it in factory. They did a very good job also me and this is my adhesive that I stick on the blade.
For this time I choosed a positive etch.
That's my fluid chosen for etching. A very cheap liquid disgorger. I read it the chemical composition: it is sulphuric acid in 90%. It is right this enough to stain every steel I suppose...
After finished this can I use now car battery fluid (30% sulphuric acid is fine).
Otherwise you can use salt water, vinegar... soemthing acid or very salty is fine
but i will use it in few drops diluted in some few ml of water: it is less dangerous and it is still effective since it is passed by DC current from my 9v battery. Those are my remembers of chemicals when I was a painting restorer.
So I sticked some masking tape previously touched several times with my fingers to loose some stickyness. It is better so no to stick too much the adhesive tape
I carefully apply on the blade the adhesive being careful to attach also the small parts of adhesive...
