- Jun 18, 2007
Hello
For those of you who do file work on the spine of a blade, I have a question for you. Do you do your file work before heat treat and protect your work from scale with some anti scale formula, edge quench to keep the spine soft and do the file work after heat treat, or draw the spine back after heat treat to soften the spine enough for the file work.
While each method I mentioned should work, I am curious as to how makers feel about which is best. Pros and cons of each that I may overlook.
Thanks for your input
Brian
Brian
