- Apr 7, 2006
In material science classes and applications at my work, I have found that the surface finish greatly affects heat transfer in metals. A mirror finish on a bar of steel provides exactly the surface area of that bar for heat to dissipate from. If that bar is sand, shot, or bead blasted, the surface area can increase by as much as 100% due to the micro vertical surfaces that are now present on the surface. When heat treating, I have found that the time the bar is removed from the heat source until the quench is extremely critical. Also, the time it takes the steel to cool in the quench is also critical (less time means greater hardness). I wonder if a sandblasted blade would heat treat better than a semi-finished or finished blade. What are your thoughts on this?
