- Feb 28, 2006
Hi Friends,
I have a few question regarding forging out blades. I've only hammered out a handful so am just at the beginning of the beginning.
The Steel
I'm using 3/4" round 5160 from Ray Kirk.
Heating the Steel
I'm using a coke forge so heating the steel is my first challenge. I'm getting a bit of a feel for temperature control, but it's somewhat like walking a saggy tightrope in an intermittently billowy and gusty wind. Steel temperature is dependent on where the steel is in the fire (between the center and top, NOT below the center), how the coke is stacked (a bit raked over the steel), how I crank the blower (slow and steady) and how long it is in the fire (approximately between 15 to 30 seconds).
Being more or less in control of all four aspects you'd think I could consistently heat the steel to the same temp each time, but noooooo. Almost half the time I pull it out with a good heat (orangey color and the scale wire-brushes off easily and cleanly), almost the other half of the time I pull it out prematurely (red in color sometimes even with shadows in it, scale doesn't brush off well) and occasionally I pull it out too hot (bright yellowy, almost sparkling). For the most part I believe my steel heating control will come with practice.
Forging the Steel
Here's my next challenge area. Most of my forging has been done with mild steel. High carbon steel is definitely different. It is harder to move and easier to crack if worked too cold. I really have to force myself to stop hammering as the steel cools. Frequently I hammer too long (loss of too much heat and color). Again, I assume control of this will come with practice. This should be easier to master than the heating.
My next challenge is hammer control. To watch me with the hammer you'd think I was a virgin teenage boy attempting his first lay (all over the place). I'm trying to keep my elbow tucked in and lift up straight and down straight as crackshafty piston like as I can. I'm trying to hold the handle loosely and whip my wrist at the end of the down stroke. It's all good until I need to work tight up against a transition, like tang/blade and ricasso/bevel. Again, this should get steadier and truer with more forge hours.
So, now for some questions. I know there are many ways of doing things. I'd really appreciate hearing yours.
Thanks guys!
All the best, Phil
The Steel
Heating the Steel
Forging the Steel
- Where do you start when starting with round stock? Do you forge it out flat first before starting in on your tang and blade? Or...???
- Do you do your blade or tang first? And how do you go about it? I've tried using just hammer and radius anvil edge like swages to pinch out the tang, but my hammer control isn't good enough. So I'm using a guillotine-like contraption.
- How to you set your ricasso and blade bevel transition?
- How do you keep the ricasso thick and not thinned out into either the blade on one side or the tang on the other?
- How close to finished blade shape and size do you go? Conversley, how much grinding/filing do you leave to do?
- When do you set the shape and angle of the tang in relation to the blade so it will line up with your intended handle shape and angle?
Thanks guys!
All the best, Phil
