After some informal research here and elsewhere, I've created the following rough draft of representative blade geometry specifications for high-performance knives, and would appreciate your input to adjust and optimize it. With your help, I think a revised iteration could become a spectacular resource for up-and-coming knife makers among other audiences.
I'm primarily seeking input from makers or other highly-informed members about their geometry preferences. It's been mentioned that makers often grind thinner as they gain experience. Please list your own ideal row values, even better as an associated combination for each favorite knife. Values are critical for impact tools, so special attention will be appreciated there. Id love input such as "Your edge thicknesses look too thin for the intended application. I'd increase [chef's] to " or especially a few rows in the format of the above table, each describing a favorite knife geometry combination.
To avoid innumerable combinations, my generalized column values are disassociated from rows and treated independently, esp for min/max ranges. Therefore I'm not necessarily assigning a precise charpy-C value to a listed steel or hardness. However your column values for a specific knife can be mutually dependent, all the better. To simplify otherwise exhaustive geometric definition, each entry is intended to be representative, not comprehensively inclusive. Thus a width may be a representative sample in the middle of the blade, and a thickness may be nearer the handle and not reflect distal taper. Obviously there are possible outliers well beyond the intended main-stream ranges, but I don't think we need to address extremes like tuna knives. The subtopics are broad enough for forum-wide debate, so let's please keep discussion high-level, amiable, and on-topic (e.g. lets avoid degenerating to fighting about favorite steels or chiming in without substantive input).
Thank you very much for your detailed consideration and contributions.
| Use | steel | hard | Charpy C | spine | edge | edge < | bevel | blade | blade | grind | weight | |
| class | HRc | ft-lb | thick | thick | dps*2 | width | width | length | oz | |||
| Razor | AEBL | 60 | 35 | 0.03 | 0.005 | 12 | 0.04 | 0.25 | 1 | hollow | 3 | |
| Paring | AEBL | 60 | 35 | 0.04 | 0.007 | 15 | 0.08 | 0.25 | 3 | flat | 4 | |
| Filet | Elmax | 59 | 35 | 0.06 | 0.01 | 17 | 0.25 | 0.3 | 7 | flat | 5 | |
| Slicer | Elmax | 61 | 25 | 0.09 | 0.01 | 19 | 0.5 | 0.6 | 9 | hollow | 6 | |
| Chef's | AEBL | 61 | 35 | 0.125 | 0.012 | 20 | 1.5 | 1.5 | 8 | hollow | 10 | |
| Skinner | PD1 | 61 | 35 | 0.125 | 0.015 | 23 | 0.8 | 1 | 3 | hollow | 6 | |
| Utility | PD1 | 60 | 35 | 0.125 | 0.018 | 23 | 0.65 | 0.8 | 5 | hollow | 7 | |
| Tactical | CPM 3V | 58 | 80 | 0.18 | 0.025 | 25 | 0.6 | 0.8 | 6 | flat | 9 | |
| Hunting | min | CPM 154 | 59 | 25 | 0.11 | 0.015 | 20 | 0.6 | 0.8 | 4 | hollow | 6 |
| max | PD1 | 62 | 35 | 0.15 | 0.025 | 30 | 1 | 1.2 | 7 | hollow | 11 | |
| Survival | min | 52100 | 57 | 30 | 0.13 | 0.015 | 20 | 0.6 | 0.8 | 4.5 | hollow | 7 |
| max | CPM 3V | 60 | 70 | 0.2 | 0.03 | 30 | 1.3 | 1.5 | 9 | flat | 18 | |
| Machete | min | 5160 | 52 | 50 | 0.09 | 0.015 | 25 | 0.25 | 1.3 | 14 | flat | 11 |
| max | Z-Tuff | 58 | 115 | 0.13 | 0.035 | 35 | 0.5 | 2.3 | 24 | convex | 30 | |
| Chopper | min | 5160 | 54 | 50 | 0.16 | 0.015 | 25 | 1 | 1.5 | 10 | flat | 16 |
| max | Z-Tuff | 60 | 115 | 0.375 | 0.03 | 35 | 2.5 | 3 | 20 | convex | 40 |
