- Jun 20, 2007
I am asking this because I am in the planning stages/ securing all my material for building a KMG clone, and a question has arose in my mind.
I don't know this answer because up this point all my knives have had the material removed at the grind area by roughing with a side angle grinder, file and sandpaper, in other words a flat cut on the bevel.
So I assume using a wheel to produce a hollow grind the girnder is turning towards yourself / counterclock wise or into the material. Therefore you are grinding blade up or looking into the blades edge as you grind.
I also understand that is the reason for the centerline on the edge to allow for you to watch that you don't take off to much. Since grinding in this position means you are blind to the back / spine edge of the blade cut.
I am I misunderstanding the rotation of the grinder or the blade up approach?
How do you know that you are not taking off too much at the back / spine of the grind line?
Do you just mark it and keep grinding into the spine until you reach the mark?
I know these sounds like elementary questions to some but it just struck me a while ago when I was thinking over the hollow grind process! Any advice would be appreciated.
