I apologize in advance if this is the wrong forum or a question that has been asked before. I've been lurking on this forum for several years, and finally ran into a situation I can't find an answer to. My current quest is to find "the" deer field dressing knife. I narrowed it down to the Fallkniven F1, a Becker BK16 I customized and the new Cold Steel Master Hunter 3V. I have several Master Hunter Carbon V blades, so I somewhat knew what to expect from the CS 3V. I sharpened each blade on a Ken Onion flavor Work Sharp with the blade grinding attachment using 600 grit. I then stropped with the leather belt. Each blade would easily slice paper or pop arm hair. I shot two deer this weekend so the test was on. The Becker did the job with very little effort. It would just glide through whatever I was cutting. I skinned one of the deer with it and the edge was still paper slicing sharp. The Cold Steel with 3V was the surprise. It simply didn't like slicing meat or other soft tissue. It would do the job, but required considerably more effort. The F1 did fine as expected, but still not up to the Becker level. My confusion is to why the 3V blade didn't perform better on soft tissue. I really expected the thinner blade to perform better. All of the blades appeared to be equally sharp before and after the test. Any insight would be greatly appreciated.
