I have a question about what you wrote Kevin Cashen (thanks for all your info as always). Are you saying that the standard RC testers that are used in industry are worthless? I know Bos and R.J. Martin both do an RC test on each blade and I have always found both there HT to be damn good. Are they doing test beyond doing a test on a RC hardness machine? I have been told that it must be done on the flats of a knife and that some people take multiple reading and average them. I guess what I am asking is wether or not a knife maker can get an accurate RC number for a knife. Not for marketing but for learining more about the HTing im doing and will do.
Whoa! I am not sure how
"For example, you may be tickled with a 1084 blade that Rockwelled at 66, but did you get this number because the steel was overheated? Other test will be needed to validate the Rockwell numbers in this case.
can be seen as
... saying that the standard RC testers that are used in industry are worthless?
I also can't see how any particular heat treaters or makers could possibly have been targeted by any of my comments.
I do need to make myself quite clear- I Rockwell every piece of steel that goes through a heat treatment in my shop, and even some that were done in other shops; I find the test that invaluable. But it is only one test and can only tell you so much. Because it is such a great test is why I used it as an example- even the best of tests have their limitations. They have these limitations is due to specialization, as good material tests are very accurate because they manage to measure a single property at a time.
Many makers will quickly pooh, pooh, Rockwell tests because they do not tell them what they want to hear, I am not one of those makers. And this is what I was getting at in my first post -doing things to make you blades look good for the public is sales gimmicks, doing things to learn both the good and the bad about your process and product is testing.
My Rockwell tester is invaluable to me, but what does it tell me about grain size? What does it tell me about edge geometry? What does it tell me about carbide condition? What does it tell me about handle ergonomics? If I get 55HRC on a piece that should have been 62HRC what can the Rockwell tester tell me about finding out why? I have other tools that will. Relying solely on a Rockwell tester would be as limited as just cutting up rope.
I have never got a truly reliable reading on a bevel yet, a flat surface perpendicular to the penetrator is necessary. A proper finish is also important. If one is not utilizing proper soak times a reading on the ricasso will tell you nothing about the blade, and obviously differentially hardened blades are a lost cause on a Rockwell tester.
Rckendal, some tests are perceived as standards in knifemaking because of the amount of P.R. they get, but many get P.R. because that is what they were designed for, more than learning about the product and process. I personally like the tests that tell me something I didnt want to hear about my work, it allows for improvement. Steve Hayden nailed it again in his post, I think putting blades in the hands of folks who will use it extensively for the intended purpose and then gather the feed back is the most efficient way to gather information (heck you can be making knives while a dozen of your blades are being tested), hunting knives being used by hunters is about the best practical test you are going to get. I had a friend who was a butcher, and every year around dear season he would get swamped with business, I would drop off a couple of blades with him and have him give me feed back, I learned a lot. I also still believe that the most destructive environment for any knife is in a kitchen. If a blade holds up well for 1 month in a busy kitchen, it can take just about anything!
