A simple question: If a knife cuts well, is designed to do what is is supposed to do what more can you ask?
One type of cutting test Im not sure actually tests the cutting edge is chopping some sections of firewood.
There are many video clips on YouTube I have been watching as of late , where the knife maker is able to shave hair, then pound it in some firewood. The blade splits the fire wood, and then we see that the edge still shaves hair.
But is this chopping of firewood really testing the cutting edge?
Im not too sure it is because it would seem to me that the wood can be also getting split by the pure shape of the sides of the knife.
It might be true that chopping firewood does not cause that much harm to the cutting edge on a convex grind knife blade.
But I would agree that chopping firewood is a good way to test the spine of a blade, to see how it works and how it stands up to this type of stress.
The handle can also be well tested by cutting firewood because once the blade gets stuck you may have to twist and bang on the handle to get the blade free."
I guess the real question is what wood are you chopping. Normal chopping will test the knife/steels toughness more than anything if I understand it right. But chopping hard wood would test the strength of the edge/steel as well wouldnt it? The real problem would be finding some teak you would be willing to chop on in the first place. Im tameshigiri we would cut both fresh and dry bamboo. I always got the imression the hardness of it was testing both wether the edge was deforming and the differential HT.
Very true.As noted above to attain the maximum benefit testing needs to be repeatable with other knives by other makers and in different locations.
