Pretty much whatever will do, tbh. Just keep it minimal to avoid the dirt/debris issue you mentioned.
You’ll find people here who swear by mineral oil, nano-oil, WD-40, tuf-glide, etc etc etc.
They all work. I use nano-oil, but I’d put money down that I wouldn’t be able to tell the difference between that and almost anything else in practice.
Don't use transmission fluid. It's very toxic. Even though It's absolutely a great lubricant.Over the last going on 58 years I've used 3 in 1 oil (AKA: "Sewing Machine Oil"), Olive Oil, Mineral Oil, 10W-30, Transmission Fluid (Ford/Chrysler and GM), 2 Stroke Oil, Powdered Graphite Lock Lube, Hoppy's #9 Gun Oil ...
As for "food safe" ... I wipe off any excess lube after I lube the knife and wipe the blades with oil.
I've always used whatever knife I have on me for food prep ... As far as I know I'm still above the grass ... so they must all be "food safe" if the "contamination" is miminal and spread over time.
Red n tacky grease. A little goes a long way. It stays put and doesn’t dry out.
Nano oil is snake oil but you're recommending Knife pivot lube? lmao.Avoid snake oil lubes like nano oil. Too expensive for what is just mineral oil.
Lots of good suggestions here too.. Also look up
Knife pivot lube
Its pretty new but alot of people are saying it's better than the lube they used previously By a long shot.
Always remember less is better with any liquid lube.
Look man I could detail all the bs marketing they make but when it comes right down to it, you can do that research yourself. It's clear as day it's snake oil and I'm not the only one saying it. It's also the same as diamond lube of which had even more snake oil advertising. The thing is, it's just mineral oil. So all that marketing is what's the snake oil.Any lube will work to some degree but each will make the action feel slightly different from another. Some lubes definitely feel slicker then others and some stay in place better. I have tried many different lubes and I have found that the generic cheapo lubes like hoppes, rem oil, wd-40, clp, cheap grease, all work but leave room for improvement in terms of smoothness. So far my favorite has been wilson combat ultima lube lite oil, nano oil 85 weight, and ballistol. I wouldn't take advice from anyone calling something one product snake oil because it shows they have no idea what they are talking about. No lubes contain any groundbreaking ingredients but the slight difference in ingredients and ratios will change how the lube feels, this isn't to say some are overpriced. I was skeptical about nano oil until I tried it, people say its just mineral oil which is just dumb since its obviously works differently then regular mineral oil (regardless of whether its contains mineral oil as an ingredient). I use a light grease on my guns called Cherry Balmz, many have called this overpriced moly grease yet fail to show any product for sale that feels and works the same. Frog lube is rumored to be just coconut oil, and for this reason people call it snake oil, yet you cant just use coconut oil because it will go rancid. My point is that lubes are made from a handful of basic ingredients but each ingredients or additive can have an important effect on the outcome of the product and therefore calling an expensive product "snake oil" because it might contain a cheaper ingredient is idiotic since the final product is still different.
I wont argue with the marketing or the background of the owners but its a pretty good product, even if its expensive. Knife pivot lube might be pretty good as well, I haven't tried it but Im sure whatever is in it cost much less then what they are selling it for, and their marketing claims pretty much applies to all lubes, there isn't anything special in it that works miraculously well for knives. Lets be real here all lubes use cheap base ingredients in their preferred ratio or recipe and then use fancy marketing to sell at inflated prices for profit, its not anything new its just how the market works. Either lube can use mineral oil, petrolium, or something synthetic as a base with some additives but that doesn't make it a snake oil. Snake oil would mean the product is complete bs and doesn't work, both products work neither are bad. If you go to drug store and buy regular mineral oil and i'm pretty sure it will feel different then either nano oil or knife pivot lube (especially considering there are different weights). Both products have a website with marketing and both are advertised all over social media, how is this bad? Doesn't make sense to call a product "snake oil" just because it has hype and is on the expensive side.Look man I could detail all the bs marketing they make but when it comes right down to it, you can do that research yourself. It's clear as day it's snake oil and I'm not the only one saying it. It's also the same as diamond lube of which had even more snake oil advertising. The thing is, it's just mineral oil. So all that marketing is what's the snake oil.
Knife pivot lube is not making up any marketing as far as I can see. They let the product do the talking. They don't have to make a web page with snake oil advertising to sell it.
In any case these two companies nano and diamond have a long history on the internet of snake oil scams. It's not just me saying it.
Hi,Snake oil would mean the product is complete bs and doesn't work, both products work ... Doesn't make sense to call a product "snake oil" just because it has hype and is on the expensive side.
