- Feb 17, 2007
Springs are fully hardened then spring tempered. Nobody makes a spring that is half and half or any other ration. The difference between non heat treated tool steels and mild steels? Not much.
The difference between a edge quenched blade of tool steel and a blade made with mild steel that has a piece of quality tool steel properly forge welded to the cutting edge. Not much.
Notice how thin the machetes are? If they were to soft the would stay bent. If they were to hard they would snap. The huge band saw used in lumber mills are fully hardened then tempered. The teeth are then rehardened and tempered to a higher hardness than the "body". They are bend around the drive wheel and idler a countless thousands of times and cut through miles of wood.
This thread is getting carried way beyond the point of anything real. The truth is if you properly make a blade and then edge quench it, somehow properly heat the edge and not the spine and quench, clay harden it or fully harden it and then draw back the spine area you should have a knife that only an idiot would break. If I am stuck in a survival situation I am going to use MY BRAIN and not abuse the only knife I have no mate who made it or how it was made. I have a great survival book by the British SAS and no where does it talk of needing a knife that does more that any of these can do. A superior knowledge and a brain will get you a lot farther with any decent knife than some one who does stupid stuff with the worlds greatest survival knife.
