- Sep 19, 2001
110V Shallot was 58-61, not 60-62. Phil Wilson measured mine at 58 +/-1
http://www.bladeforums.com/forums/showthread.php?t=595299
As a knife modder/tinkerer, I believe the biggest mod you can do to a knife is to sharpen it. Right after that is rehardening the steel.
If anyone is interested, I can reharden your blade for free. Any steel, any attainable hardness. But I should note that there may be some risk involved, depending on the steel and desired hardness. It's like turbocharging a car engine.
Edit: Added warning about risk involved.
What blades have you done so far? Any testimonials?
Spyderco does pretty well with their target numbers and hitting the high notes.
Awesome that you got this going, hurricane Gustav took out part the shed and set me back behind square one before I could even get started. Lost hardware, quench oil, and floor space.
Rehardening implies subjecting the blade to high (very high) temperatures. So, whatever coating it has will be gone, and you either have to clean up the blade manually or send to someone for bead blasting or other coating, or polishing. ou can see what the blades look like after rehardening.I will be remembering this. I want to try rehardening some blades. Not sure which ones yet. So all i'd need to do is send return shipping money as well?
Can you do folders? I'd really love to see how much better a SAK would be with a harder knife blade. A Cadet with a hard thin blade would be a big surprise to alot of people I think. Heck I have almost doubled the cutting ability just by putting a thinner and convexed edge on mine.
I too have an interest in this service you're generously providing. I have spare s30v blade for one of my sebbies that I would be interested in raising the hardness on. I understand that there is always a risk of some warpage developing.
From your experience what are the chances of this occurring in the pivot area of the blade? Would the warp be more prone to just the thinner grind area? I would be more willing to risk some warpage in the grind area as opposed the the pivot area.
Interested in hearing your thoughts.
Thanks,
Scooby
codtd,
This sounds like a very generous offer. I assume if we want a folder blade treated, that we should remove it from the handle and send just the blade steel.
Do you have hardness testing gear as well as HT gear?
Bill
Wouldn't it be alot easier to offer new knives with higher stated hardness levels?
There's couple things you'd need to keep in mind when rehardening. May be you already know that, but some of it was unexpected to me when I went through the process.
Also, regrinding, if you are looking into that, is far easier before rehardening.
Some manufacturers, if not most of them leave rather rough surface under the coating, because it sticks better that way. E.g. my M2 710 blade. After rehardening, once the coating was gone it exposed pretty rough grind lines on the surface. You can see that clearly on the photo attached here.
I've spent 8 hours or so trying to smooth the blade finish, mainly with 120/220 sandpaper. 64.5hrc blade didn't really respond well.
Both Richard J and Tom Krein can comment on those 2 blades too.
So, keep all that in mind when rehardening.
But in the end it is well worth it. The gain in performance that is.
Goes back to the example of the car motor, just because they say your getting 300 hp does not mean you will get it every time. I have S30V in several knives and the HT is different for all of them, even ones from the same company.
Howdy,
This sounds very interesting. I have a USA made fixed blade Gerber Stag Freeman made out of S30V. I have been disappointed in the edge retention, it seems to be similar to 420C. My guess is it doesn't have a great heat treatment, hence the poor edge retention (lower RC?).
Have you worked with any of the Gerber S30V blades? What do you think the improvement would be?
If I want to move forward with this, what is the next step?
