Blade Steels Properties
What are the best steels for a blade with both good edge holding and durability properties? I have been looking at Aus 6, Aus8, Aus8a, Aus10, Ats-34, Ats-55,M-2 and several COLD STEEL exclusives. Also, is there a difference between Aus8, and Aus8a? Any information on these or other steels would be greatly appreciated.
i use 440c, ats-34, d-2, and 0-1. ats-34 being my favorite. i have bg-42 being shipped to me, it supposedly out does 440c and ats-34, but it's harder to work that d-2 which it also out does. i have a small bar or m-2, which is pretty much the most expensive steel in knifemaking, but can only be used in small knives, becuase it is brittle.
I use ATS-34 for most of my blades because you can control the hardness and flexibility of the heat treat. Some materials like BG-42 are too brittle for most applications. Consider the hardness you desire for the type knife you want to make then choosing the blade steel will be easier.
Gene Osborn
Center Cross Metal Works
I Carry My Crosses for Christ to Give any Glory to God.
AUS-8A is a misnomer. I believe that it first came from Japan and was known as AUS-8. Other sources produced it and called it 8A. Since then people have mushed the names together and called it AUS-8A.
I like the blade steel properties chart from Linder Cutlery in Solingen, Germany. It has both the chemical composition and typical rockwell hardness of cutlery alloys in one chart:
http://www.linder.de/English/InfoE/StahltabE.htm
I think BG-42 is one of the best alloys around. It is very pure and tough. It is a stainless that takes an exceptional edge more easily than most. I generally consider it tougher that ATS-34 and a lot easier to sharpen.
i've heard bg-42 is flexible. it has 4% moly and some vanadium so it deffinetly should be. it's double vacuum melted, and clean, way beyound that of ats-34.
well....as 18 years of knifemaking has taught me...out in the field is where the rubber mets the road. from what i have seen bg42 is not brittle, nor does it out perform d2 in edge holding. both of these steels have an edge (pardon the pun) over ats-34 and all its japanese cousins. however, this is the year 2000, and we now have 420v, 3v, Talonite...and a steel industry that is moving forward not backwards...lets not get stuck in a rut....especially one that is made in another country...one mans opinion.
http://www.mayoknives.com
Have to agree with Tom, but would add that the knife type should dictate the type of steel. No way would I put any of these on a 14 inch bowie that is going to get hard use. By that same token I would not put 1084 or 52100 on a 3 inch folder. Just different steel for different jobs, been that way for hundreds of years and doubt that aspect of knife making will change much in the next hundred.
old pete
