Blade Steels
The Mastiff said:
For a knife I can't realisticly get now I'd take S125V,CPM M4, CPM 15V, T1 and several japanese steels that I'll never see in my lifetime in a knife here.
Try Carpenters Maxamet, it has shown an increase in tool life of 300% over T15 :
http://www.cartech.com/products/wr_products_tool_maxamet.html?leftn=cpp&lefto=empty&lefti=cpp_tds0
The hardness is 70+ hrc and the wear resistance is extreme. It is used either as a high hardness/wear upgrade to conventional HSS such as T15 or as a high toughness upgrade for cemented tungsten carbide. Most manufacturers have these "bridge" alloys.
-Cliff
I'm kind of surprised no one hasd mentioned S7 or S5 for a big fixed blade. Easily my favorite. For smaller blades i have some M4 on the way, and i'm hopeful...
Larrin said:
It has excellent corrosion resistance, I've never seen heat treated AEB-L with a spot of rust on it. Some Kershaw users have seen rust spots with 13C26, but those were all bead blasted blades.
Kershaw is also running it soft and there are many ways this will reduce the corrosion resistance. In particular for example there is a 30% increase in dissolved chromium in Uddeholm's UHB stainless 46 (very similar steel razor blade steel) when austenized at 1100 C vs 1000 C. In general the stainless steels should be ran towards the upper end of the hardening temperature to maximize corrosion resistance and require oil/cold + low tempers. This same hardening will also maximize hardness and edge stability.
-Cliff
-Cliff
Do you know of anyone who uses it?
i like 12c27 from sandvik, beacuse its tough, it haandles lots of abuse and doesnt snap for nothing. i also like s30v for the edgeholding, but its a bitch to sharpen, to get a really good edge on it you need diamonds.
VG10 and ATS34/154CM. And maybe AUS10 once I use it enough.
Because they get sharp with reasonable effort,
are stain resistant in my usage pattern
hold the acquired edge through a great deal of cutting,
are tough enough to accept being used to cut non-std items without chipping, and
can be found in knives in my price range.
Any Steel I want? I think I like ATS34/154CM the best(through pure subjectivity). "Please sir, may I have some more?"
CPM3V, twice as tough as A2, Almost four times that of D2 and more than double the wear resistance, even though it only has about 7 % chrome it is very stain resistant, I think about on par with D 2. I use knifes as cutting tools and treat them as such so I like to heat treat 3V to about 62 RC and set the edge to about 12-14 degrees. It is fantastic combination that gets a very sharp edge that holds very well. However you will need DMT diamond stones to sharpen it, unless you have got all day.
http://www.crucibleservice.com/datash/ds3Vv5b.pdf?CFID=1021242&CFTOKEN=24133669
Leon Pugh
154 CM. Need I say more?? This is the best combination of stain resistance with edge holding capabilities that can be easliy sharpened in the field. Sorry S30V!!
