Cliff Stamp
BANNED
- Oct 5, 1998
But the fact that you can just stone it is a nice change over S30V.
What exactly does "stone it" mean?
-Cliff
I mean that you can run a standard sharpening stone over it and sharpen it. Some of the super steels out today wont sharpen at all with the fine grit stones and have to be hit with something rougher. I in no way am supporting using a rock or stone to sharpen your knives lol.
Yes if you are comparing two knives side by side for sharpening it is best to have two knives with similar bevels edge angles ect... I think we can still talk about ease of sharpening.
Also the hardness of that S330V or ATS 34 might be playing into it as well.
However I do not think anyone has ever accused S30V as bieng an easy to sharpen steel.
Some of the super steels out today wont sharpen at all with the fine grit stones and have to be hit with something rougher..
... the proper use of relief bevels (applied by an apropriate medium) will make the ease of sharpening (with respect to time spent going from dull to sharp) a non-issue.
In my opinion a good knife steel should be regrindable with a ceramic grinding rod/stick.
In the same range of hardness as the high carbon stainlesses (59-61), it's in the 34-40 range, not 20-30. 440C gets 26 ft. lbs. at 56 Rc, and 16 ft. lbs. at 58 Rc. 154CM is somewhere around 16 ft. lbs. at 60 Rc. S30V is 20-25 ft. lbs. at 60 Rc. And at 60-62 Rc, L6 gets 43 ft. lbs., you have to get down to 56-58 to get 68 ft. lbs. Just because there are steels that have much higher toughness doesn't mean that CPM-M4 does not has far more toughness than required for a chopper either. Osbourne says that S30V is the closest a stainless came to working as a chopper, but he uses a knife for a month before he deems it useable, and his S30V didn't last a month, it eventually started to chip. I don't know what other stainlesses he used, but testing 154CM seems likely for him, but I can't say for sure. The excitement for CPM-M4 is that it has plenty of toughness for heavy use blades (i.e. choppers), and it also has some very high wear resistance. It is that balance of properties that is quite possibly the most sought after in a steel, disregarding corrosion resistance. Being comprised of molybdenum and vanadium carbides at a total volume of 12%, the carbide size of CPM-M4 is slightly larger than 3V, but is smaller than 10V, S90V, CPM154, and S30V, so it takes a pretty keen edge too. There is a point of diminshing return for higher toughness depending on the application and the design, but a higher wear resistance will always bring an increase in performance (and a decrease in ease of sharpening).BigJim-
You keep talking about this steel's toughness and impact resistance, but on paper it certainly doesn't look like much to get excited about. I have no experience with this steel either, so don't want this to come across wrong, but if I needed a tough steel I'd skip past the steels with only 20-30 ft lbs in the impact tests. That's pretty much in the ballpark of high carbon stainless steels, i.e., "brittle". Contrast that with L6, which gets in the 70's, or S5, which can get like 130 ft-lbs at 61 Rc.
I'm not gonna discount it entirely, because that edge thickness quoted by Osborne does sound nice & thin, but then again that's for controlled use by a very skilled individual. I'd be curious to know what that blade would look like the first time I accidentally whack some concrete with it while coon huntin'.
I dont know about concrete but M4 blades ground as thin as Osborne stated choped much wood and cut metal cans at the cutting competition and had little enough edge dammage ...
M4 from all acounts is very tough to grind, but is supposed to be easier to sharpen then other high vanadium (4% I think in M4) steels.
As far as grind geometry I understand that due to its toughness M4 will develop a wicked burr wich of course must be removed to get a sharp edge.
Like I said, I have an S30V blades that dont sharpen well at all with a fine ceramic rod I use in the field ...
Most of my knives have similar profiles including some low alloy carbon steels. I have a 1095 blade at 66 HRC for example which sharpens really nice, almost no burr formation. Grindability really isn't a factor because I only actually sharpen the edge which is about 0.1 mm wide.All I can say is that if you had that same wilson in a Carbon steel I think you would agree that the is easier to sharpen ...
Osbourne says that S30V is the closest a stainless came to working as a chopper ...
Oh, and Osbourne says that the distance between too thin and too thick for a chopper is very small. I can't remember what the tolerance was, but it was very small.
