- Jul 28, 2006
I need to get some material for a lanyard tube that will take hot bluing, any suggestions? I can get some mild tubing but it's larger than I really want to use. I need something around 1/4" or so.
just chuck the rod stock in the drill and put a loose vise under it. lower the press into the vise and tighten the vise on the rod stock. and then clamp down the vise, unchuck the rod and replace with a drill bit, drill your hole and you have tubing or washers for shadow slipjoints. sounds complicated but If I can do it surely you can.
Rusty
