Don't forget, 15N20 is carbon steel as well!
It just has a little nickel that keeps it from etching, which creates highs and lows.
The bluing process turns the entire blade completely black. It's just bluing the iron in the steels and doesn't know the difference between the two.
Then I sand the bluing off the "high" 15N20 to exaggerate the pattern.
As well, consider that the "lows" are now protected by being hot blued.
The oils used in the process are water displacing oils from Brownell's, as are the salts.
There is a considerable set-up cost for the salts, oil and tanks, but after that there's no real expense other than time.
Phil, the salts "creep" with the evaporation of the water - not much can be done about it other than eliminate as much evaporation as possible. I've devised a plastic cover for my tanks which help some.
It's not a big deal and more of an annoyance than anything.
Part of the game.
Set up, get going on it, and you and your customers will be glad you did. :thumbup:
