- Feb 17, 2007
I know this isn't a gunsmith forum, but, some around and a lot of bluing experience too.
I have an S&W that was originally a 45 ACP with the 1/2 moon clips. I have rechambered a 44 special cylinder to 45 LC. Yes a S&W 45 ACP-45LC convertible and I cast and size my LC bullets to .452 btw. I have also turned the barrel down and made a sleeve for it to make it into a heavier barrel. I have added S&W adjustable sights. I am making an ejector shroud for it now. While the gun is in very good shape, the blue is worn off in spots and I want to refinish and have everything match. What is the best way to remove all the old bluing. Should I just sand it off with say 1200 grit paper or use something else? Thanks Jim
PS. I used to shoot practical revolver courses and am thinking about restarting. A heavy 45ACP revolver would be great for this if you are a wheel gun nut. Using the full moon clips that hold 6 rounds means very fast reloads, easy brass pick up and big holes and with light loads very slight recoil. I have also done quite a bit of successful handgun hunting and I don't believe that at reasonable ranges (under 100 yards) a good 45LC gives much away to a 44 mag. I have had 3 44 mags btw. 2 S&W and one Ruger that I put a 14" barrel on. I even made a S&W 41 mag and used it for a while. I love Smiths.
