- Mar 5, 2009
Which one should I get (first)? Experiences positive/negative with either?
I also wish Spyderco would at least attempt to sell at least one model with assisted opening. Kershaw makes more assisted folders than non-assisted, so there's little risk of them not selling. Hell, Spyderco could sell dog turds as long as the bug logo was on them. But Sal Glesser & his minions seem to be adamant in their disdain for assist. C'est la vie.
This. Plus 1Chris "Anagarika";10015105 said:One thing is obvious, hole is much easier to manage and use under stressful situation than studs, but YMMV.
With hole, your thumb is 'enclosed' and unless there's slippage, any force put will drag the blade out, even if the direction is not 100% accurate. With studs, if your direction of push is wrong, ypur thumb will 'leave' the studs, which is what all AO thing try to address. By nature, hole openig will not benefit from AO because the thumb is 'trapped' by the hole, so it will not allow AO to take over, but nor it needs AO to take over as the thumb will always be fully engaged.
In my view, the hole is a genius invention, as it allows full control over the blade opening action. Even among sheepies, you can open the blade partially, hold it in place, do the cut (assuming instant coffee package i drink) and close it. Very discreet.
Minions huh?
What's the ratio for Minions to henchman? Thet get a benefits package unlike the Minions, right? Personally I'd rather be a henchman and if there are any openings I might apply. Seems like a cool job.
"Hench 4 Life! "
Pretty safe to say we'll never see thumbstuds on a Spyderco. It would have to be a flipper AO with at least the small token Spyderhole ala their fixed blades, but more likely a full sized functional hole.Chris "Anagarika";10015105 said:Try buying & using Navy k631 and Enlan EL02 to understand what a Spyderco vs BM feels given similar size vs design / ergonomics.
Having it in person & use it can't be represented by specs & pictures. Since the Chinese brands are much cheaper, you can get both, use them as comparison tools before making a decision.
The two are similar, yet a world apart.
Prototype Spyderco Brad Southard Flipper
