Up for sale today is my Direware Solo V5, latest model. BNIB, never used, carried or cut anything, only out of the box for pics and initial inspection. This is a flawless example of Eric's work, rock solid early lockup w/no play in any direction and zero lock stick, perfect centering and super smooth action, it flips like it's on bearings (because it is). It sport's the traditional tanto/recurve multi grind blade that have become emblematic of the DW brand and is shaving sharp.
This is a LSCF show side and tumbled bronze lock side model with "Carbon" gray cerakoted m390 blade. The bronze colored ano perfectly accentuated by the matching threads in the LSCF and the blade matches the color of the CF nicely as well. Beautiful piece and the definition of overbuilt; if you like big beefy folders this is for you. Comes in original box with web slipcover and Direware card. Direwares are known for being big and overbuilt but what is often overlooked is the technical precision of Eric's work; this is by no means a clunky knife, it's mechanics and ergos are second to none!
Specs per Direware website:
MODEL: SOLO
OPEN LENGTH: 8.50 inches
BLADE LENGTH: 3.40 inches
CLOSED LENGTH: 5.10 inches
BLADE DEPTH: 1.72 inches
BLADE THICKNESS: .180 - .190 inches
BLADE MATERIALS: Bohler M390
HANDLE FRAME: Carbon Fiber
HANDLE FRAME LOCK SIDE: 6AL-4V Titanium
SPACERS: This model comes with a solid back-spacer made of hardened 440C.
SOLO NOTE: The current SOLO build comes with a 25% thinner frame, improved edge geometry, smoother bearing system, improved clip design, new blade choices, new frame choices, camouflage pattern options and ceramic coating options.
Asking price on this one is $old NET shipped in the conUS.
International Shipping at buyer's exclusive risk and expense. First unconditional "I'll take it" has priority but prompt follow up is required.
MODEL: SOLO
