flaxseed oil is good for you, but as noted the finish grade oil does have metals in it to speed drying. Not edible, and not recommended for items used for food (bowls, spoons, etc.). Walnut oil is also edible and also works as a wood finish.
Pat
i'm guessing that in some cases, the impurities in many "non food grade" products is a side-effect of the cheaper process they use to make the stuff; as they don't care so much... and it's convenient if the metal impurities somehow make it dry faster... it's still got to be boiled though, right? otherwise it will never quite dry properly...
also, as a lot of this stuff goes into paint anyway (toxic usually), they really don't care, but there should definitely be warning on the can/etc not to use on food grade products. you'd think too they'd warn you on items that people might later touch, or handle, or chew (children's wooden toys). i'll go look again, but having read the safety sheets online for a number of boiled linseed oil products, as well as every label in the can, i don't recall that. mmm.
bladite
Boiled linseed oil is not boiled anymore, although it is heated in the extraction process, its just a name they sell it under. The heavy metals are added as driers!
All sorts of chemical extractants & solvents are used in non food quality linseed oil. The days of simpley pressing for oil for use in industry are long gone!
It can cause all sorts of mutations of human cells in you & futre generations if ingested.
Spiral
...It can cause all sorts of mutations of human cells in you & future generations if ingested....
here's the data sheet for the stuff i got:
http://www.wmbarr.com/msds/index.asp?zoom_query=linseed&zoom_per_page=10&zoom_and=1&zoom_sort=0
doesn't mention nuttin about heavy metals, you'd think they'd HAVE to. i'm told that yeah, some is made that way, but not all. they DO say "inedible", but if they're using heavy metals and NOT saying so, they'd be liable for some action down the road i'd imagine (skin contact alone).
Bladite
Bladite
Again, the Tried and True finishes, linked in my earlier post, say in the promo material:If they tell you to use gloves or advoid skin contact there covered.Other than that I dont know perhaps its not got the added driers?
But as others said. Id use food safe myself, or walnut oil.
Spiral
Spiral
Premium Quality Interior Finishing Products
made from
Polymerized Linseed Oil
Environmentally Safe
Solvent free - Zero VOC
Food Safe
No Heavy Metal Driers
[/COLOR]...which would be why I use them.
t.
