I purchased a Boker trance and have been EDCing it for a month or so. I had been thoroughly enjoying it.
I was doing some electrical work, and used my Boker to cut a zip tie that was holding a cluster of wires together. I was quite disappointed when a short time later I noticed small chips in the portion of the blade that I used to cut the zip tie.
I can see this happening if I were abusing the blade, but cutting a zip tie is far from abuse.
The blade steel is AUS 8. Is this a common occurrence with this steel? could it be due to bad heat treating? OR might it be due to improper sharpening? (I use a spyderco sharpmaker) Might this be remedied by Bokers costumer service? thanks for your input.
Picture Below
Picture Below
