I use epoxy to seal them and pins, penned into the countersink hole. They can't come off, and if the fit is perfect you won't see the epoxy joint. One other tip on pins, buy your pin stock from the same supplier as your bolster or guard materials, there are differences in nickel silver from different suppliers, and when polished there can be a slight color mismatch between the pin and bolster, not sure about brass.
Dale
