For $30K+ you ought to get a lifetime warranty on a new car too but that will never happen.
Even with the limit on the H.I. warranty, it's still one of the best in the cutlery business.
Not true. Cars are made up of many components known as wear items. These plus planned obsolescence prevent cars from being much of a durable good. Factory car warranties are for the manufacturer's intended lifetime of the car. You're not expected to buy them and drive the wheels off of them, like I do. You're expected to put 50-100K miles on it and then get rid of it.
Cars are largely not built to last.
Good knives are. My HI kerambit and tamang certainly are built to last.
I keep my knives forever, provided they're not junk.
No doubt, HI has one of the best warranties in the knife business. I would like to see more clarification concerning uses that are and are not covered. If a company can arbitrarily say that a failure was abuse/not intended usage, without specifying what intended usage is, or examples of abusive uses, the warranty isn't worth much.
If the blade on a knife of this size and thickness breaks or chips, it's a failure in material or heat treatment. The steel should not be brittle. It should be hard, but tough. If it chips or breaks resulting from chopping, the steel is too hard.
If my cold chisels break as a result of using them to cut steel nuts or bolts, they get replaced under warranty, as they should.
My question about the warrant-ability of the BC for cutting bone was largely rhetorical, as I have a recip saw that I use on big game legs.
I just want to be sure that HI will stand behind it's products, because I really like them, and I like Yangdu and would hate to have a reason not to buy from her.:thumbup:
Odds are, if there's a problem with material/heat treat, it will rear it's ugly head early on. Let's hope that doesn't happen. It is a real risk that the manufacturer assumes by using scrap leaf springs instead of virgin alloy.
That said, barring microscopic cracks, old leaf/coil springs/torsion bars, broken axles, and forklift forks are my favorite raw materials.
Speaking of which, I have a 19" long piece of 1-3/4" diameter forklift drive axle. Ya reckon the kamis could make a giant cold chisel from it for me?
Now, if my BC would come in so I could start splitting some of my oak and hickory pieces for use in my smoker, I could take the sawzall to this deer leg in my freezer and make some good smoked Bambicue.:thumbup:
Yes, I do want an HI ultimate meat cleaver, but I'm saving up for a Tarwar.
I'll make truly the ultimate meat cleaver from that big truck leaf spring.
It may take 2 or 3 of us to swing it, but by gum, it'll chop bambi femurs or petrified wood.
Now, if it'll split sweetgum it's really accomplished something. That stuff is like trying to chop big blocks of rubber.
