Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
This is one stout folder, as most Bose/Case yearly issues usually are, and this is maybe even a bit stouter than most, well except maybe the lock back whittlers. This one is from 2011 series, antique bone it's called, while the jigging is excellent, I will warn you, if you have one you will want to scrub the scales a bit before pocket carry as the dye they use on there can rub off, I've washed this one a bit and it's seems to have calmed down in that respect.
Measuring approx. 3 1/2" closed and thickness wise just over 1/2" thick from scale side to scale side. I don't have a scale to weigh it on, but she's a chunky delight. With the wrap around liner for the pin blade it adds to the weight. At first I was put off from it's chunkiness, but have come to appreciate it's weight and size. Been using her at work, very handy both main and pen blades and they both took an exceptional edge on that 154cm steel.
As you may think that I made a typo on the title of the thread, I have always felt better putting the Bose name ahead of the Case name...just because.
Thanks again Tony for these great knives you help Case to put out each year!
Here are some images of the knife, and a knife purse, which I do have a permit to use, signed by Tony too. It makes it easier to get to, especially when seated. Plus it helps to keep the gunk out of the knife too.
a nickel for size reference, it's a fairly thick folder for being so narrow
and it's always nice to see this on the tang of your blade, even if it's a Collab, still it brings a smile to your face
Please feel free to post images of your Coffin Jacks.
Thanks again Mr Tony Bose !
G2
G2
