Hal Golightly
- Jan 1, 2007
Lenslight 3X123
This 3x123 flashlight is a dual output model with a CREE XM-L2 LED. The high output mode is by default the first mode, while the second mode is low mode. They 2 modes are easily accessed with additional on/off clicks. The body is Tan type III hard anodized 7075 aluminum with a Strike Bezel. Includes titanium clip. Powered by three (3) CR123 batteries or RCR123 rechargeable batteries.
LensLight manufactures premium flashlights that are designed and built to last a lifetime. These lights utilize a high-impact hardened optical glass lens that utilizes LensLight's patented Focusing Aspherical Lens System to provide the user with a flood beam, spot beam, and everything in between. The glass lens is super tough. It has been vigorously tested and designed to withstand abuse and perform without a hiccup.
All LensLight flashlights use a high power LED for the best efficiency, output, and reliability. They are equipped with a McClicky momentary and constant-on tail cap switch. The body is outfitted with strategically placed premium o-rings to ensure longevity by protecting the light from the elements.Mode: Output / Runtime on high is 850 lumens / 2.5 hours and low is 5 lumens / 100+ hours. Comes with box and paper and extra o rings, it has not been carried or used, the only thing I did with it was put batteries in it to see if it works then it went in a drawer till now. $175.00 shipped USPS, I accept PayPal and USPS money orders. Sales only to USA. Sold and shipped.
Surefire Minimus AA Headlamp
When it comes to reliability and power Surefire is the brand to trust, and the Surefire Minimus AA Headlamp is no exception to their long history of high quality lighting equipment. A powerful solid state LED diode allows this headlamp to reach outputs of up to 100 Lumens, and the output is fully adjustable. The light can meet any output level between zero and the full blast of 100 lumens. Light adjustment is handled via ha knurled no-slip control knob mounted on the right side of the device. The headlamp is held in place using an adjustable fine-weave headband and patented Breathe-O-Prene that helps hold the light in place and prevents slippage from moisture.
One of the most remarkable features of Surefire lights is there legendary reliability, backed up with a lifetime hassle free warranty from the manufacturer. Each piece of this headlamp has been designed with the prevention of failure in mind. The body of the light is crafted out of tough polymer material in conjunction with hard-anodized aerospace grade aluminum, which makes the light not only highly damage resistant but lightweight as well. The LED itself is a wonder of modern technology, and its solid state lighting power can handle far more abuse than traditional incandescent bulbs ever could. Even the fine-weave headband has been tested in harsh environments and will find itself at home in fire fighting, combat or any rough situation that can be thrown at it.
The Minimus is a sturdy tool but certainly not an inflexible one. Besides the fully adjustable light output, the housing of the light can be angled up or down with 90 degrees of articulation. This allows users to manage the light source in the exact location it is required without putting strain on the neck. For emergency situations there is an SOS features that can remain blinking for several days uninterrupted. The light features the following: a virtually indestructible LED emitter regulated to maximize output and runtime, variable-light output dial controls levels from 0 to 100 lumens, proprietary refractive optic produces a smooth, wide beam optimized for your field of view, built-in SOS beacon can run for days on end, light housing can be rotated up and down 90 degree, high-strength aerospace aluminum body, Mil-Spec hard-anodized for extreme durability, a headband that provides comfort, durability, and a secure fit with or without a helmet, Breathe-O-Prene forehead pad wicks away moisture, runs on: 2x AA Batteries Output mode/Runtime are high at 100 lumens / 1.5h and low at 1 lumen / 50h. No box or paper, has been used a couple of time but mostly it has set in a drawer not being used. $95.00 shipped USPS, I accept PayPal and USPS money orders. Sales only to USA. Sold And shipped.
