BRAND-NEW Aimpoint Comp M-4
hotrodKelley
BANNED
Feedback: +24 / =0 / -0
Hello. I have a Brand-new in box, never used, or installed Aimpoint Comp M-4. This comes in the box with warranty card, scope, battery, scope covers and anti-reflective device (ARD). I bought this and just never got around to use it, as I sold the rifle I was going to mount it on. Here what Aimpoint says about it:
In 2006, the US Army's Armament Research Development and Engineering Command (ARDEC) ran a series of competitive tests to find out if there was another sight out there that could surpass the performance of the existing M68CCO sights. Every manufacturer of combat optics sent samples for testing, and when the results were finalized, Aimpoint was once again awarded a new contract for 163,000 of this new sight - the CompM4.
The Aimpoint CompM4 is now the latest version of the US Army's M68 CCO (Close-Combat Optic), continuing the legacy that Aimpoint has maintained since 1997. The CompM4 is the finest sight that Aimpoint has ever produced. Improvements include increased energy efficiency that provides over 8 years of continuous use from a single AA battery!
The CompM4 incorporates an integral mount that eliminates the need for a separate ring, and can be customized with vertical and forward spacers to fit a variety of firearms. Primarily designed for use by law enforcement and military units, the CompM4 is a great choice for competition shooters and hunters looking for a rugged sight for predator hunting or other low-light applications.
The performance of the Aimpoint CompM4 is optimized for use with all generations of night vision devices (NVDs), but is especially suited for 3rd generation night vision technology. Aimpoint's unique band-pass coating on the front lens gives the highest possible dot brightness with the smallest amount of energy while providing the clearest, brightest image possible when used with a 3rd generation NVD. With 7 NVD-compatible brightness settings and 9 Daylight settings including one extra-bright setting, the CompM4 is ready for duty 24/7.
Compatible with every generation of Night Vision Devices (NVD)
Super ACET technology allows up to 80,000 hours (over 8 years) of daytime operation on one AA battery
1x (non-magnifying) parallax free optic
Internal voltage regulator allows the CompM4 to be used with any AA sized battery
7 night vision compatible settings and 9 daylight settings
Improved rotary switch will not suffer damage under normal use
QRP2 mount has twice the clamping force of the original QRP, and the mounting knob is wider and shorter to improve operation and lessen the chance of becoming snagged on other gear
Mount base is “keyed” into the body of the sight to absorb recoil
Mount base screws directly into the sight – no separate sight ring is required
500,000 hours of use on NVD setting
2 MOA dot for close combat and long distance engagement
Matches perfectly with Aimpoint 3X Magnifier
Unequalled light transmission
Front lens opening is threaded for addition of the Killflash anti-reflective device (Included)
Submersible to 150 feet (45 meters)
Vertical spacer included
Standardized as the U.S. Army’s new M68 CCO
Improved adjustment caps are easier to remove and are protected against impact
Can be used with a carry handle adaptor
$600.00 SHIPPING INCLUDED
