Brand New Discontinued Spyderco Szabo Folder.
This is one of the best fighting folders. It sports an imposing 4.6" scimitar-shaped blade made of very sharp S30V steel, with a partial hollow grind which creates excellent edge geometry while reinforcing the spine for increased strength.
An unsharpened swedge on the back of the blade ensures an acute point and flows smoothly into a scalloped area on the spine that enhances the blade’s trapping potential when applied with reverse-grip skills.
The handle is constructed of Gold Line carbon fibre/G-10 laminate scales backed up by full stainless steel liners. The scales material consists of an outer layer of carbon fibre embedded with gold-coloured wire that is laminated to a G-10 base layer.
The Szabo folder features Spyderco’s high-strength Compression Lock accompanied by an internal “self-close” mechanism. Nested within one of the handle halves, this mechanism uses a spring piston to engage a plate attached to the blade tang. When the blade is closed, the piston gains mechanical leverage to rotate the plate, keeping the blade nestled securely in the handle for safe carriage.
Overall Length: 10.25"
Blade Length Tip to Guard: 4.60"
Blade Thickness: 0.157
Blade Material: S30V Steel
Blade Style: Scimitar
Blade Grind: Hollow
Handle Length: 5.65"
Handle Material: Carbon Fiber/G-10 Laminate
Tip Carry Position: Tip-Up / Tip-Down
Brand new never used or carried. Very minor wear on the box which is totally insignificant, but I mention it only for accuracy.
Price is $240 ($233 if you send payment as F&F) with Paypal and includes shipping with delivery confirmation anywhere in the USA. NO TRADES, please!
Blade Grind: Hollow
