Brass solder?
HSC ///
can brass wire be used as a solder fill?
0.040" Diameter
from Mcmaster Carr - item 8864K84
Bend-and-stay wire (soft temper)
Meets ASTM B134
Tensile Strength: 50,000 psi
Made from the most formable brass alloy, this 260 brass wire offers good strength, corrosion resistance, and electrical conductivity. Maximum temperature is 400° F. Wire has a bright finish.
thanks
No, it is called brazing and requires more temperature than soldering. Low fuming bronze is used for this and is similar in color to brass.
Hoss
I'm a little embarrassed to admit that it was only in the past year that I went to the welding supply for "brazing rod" and all I could find was "bare bronze," which I use for handle pins.
Having done countless hours of brazing, it had never crossed my event horizon that, as Devin points out, I was using bronze and not brass.
