The scales are not usually glued/epoxied based on what I have seen in others posts on scale removal, and based on some minor scale shifting on a knife or 2 after baton work - although that may just be bad hitting. Someone who has removed a lot of scales would have to confirm.
This is a timely post as I have some micarta blocks I want to make some scales out of and replace with torx or the like. My main question is how to know which "depth" of bolts to buy so it gets nice and tight.
Also - If I were to go the tube replacement route, how do I know how to measure the tube lengths to ensure the same thing (assuming the tubes come in lengths to be cut down). Or if they make standard tube sets for this purpose, how to guage tube length for different handle types, mag v non-mag, hand sanded by me, or from the shop etc...assuming there is a bit of a science and an art in getting both the correct tube length and torx/sex bolt depth etc...
I do not have a press although I have access to one. And I think I would also trust myself with that first!
Anyone have good success using a hand held drill motor?
C
