- Nov 8, 2009
I have a piece in progress with an all-steel grip and a seperate steel guard, with a hidden tang (yes, I know that I am not sane
), the grip and guard of which I would like to solder together with hard silver solder (high temp). In order to keep everything aligned during soldering, I have a mock tang that will be inserted in place while making the joint. I need a way to keep the solder from flowing onto the mock tang and soldering it into the grip, I need to remove it afterwards.
Question:
Does anti-flux work for the high temperatures used for brazing/hard soldering? And does it require a thick build up on the surface in order to work properly? There is pretty minimal clearance between the tang and the inside of the grip, so not much room to coat the surfaces without it being scraped off during assembly.
Is there another trick to keeping the solder from tinning on the tang and other areas where it isn't wanted? I though of just putting a layer of oxides on it by heating it up, but the flux does a good job of eating through it, just like it's supposed to.
Besides anti-scale compound, is there another trick to keeping the scale to a minimum during brazing?
Question:
