- Aug 6, 2007
You keep mentioning "no pitting and no scale" as a benefit to this brine quench, pitting and scale isn't formed in the quench it is formed in the forge. Which leads me to beleive that because scale usually forms at around 1500F depending on the atmosphere, so that would be the reason for no scaling and pitting is scaling on a smaller level, also the lower temperature would be helpful to a blade surviving the water quench, there is too many variables here for you to say definitely that this works better than a proper 10% solution.
There is most likely a logical reason why industry set the optimal solution at 10% because A-lots of money testing in REAL laboratory conditions proved this to be true, B-they found that slowing down was useless, because then you could just quench in oil if you wanted a slower quench.
I have some really good info on brine quenching, I have seen firsthand a 99% success rate with it with 1075, and around an 85% success rate with 1095, ask a Japanese smith about THEY'RE success rate sometime. Like any good tool it is meant to be used properly, and if used differently than that it is meant to be, then used with common sense. Because most shun industrial methods due to the fact that usually blade cross sections crack in brine or water when alot of the steels we used are designated "water/brine quenching"folks think that some modification to industrial methods and techniques is warranted. Any other time I would probably disagree, but with brine quenching which i have done with swords (3 foot, complex geometry, not 3 inch knives) a fair bit, I can say that if you look at brine quenching with a different mindset, and think it through using SCIENCE and the information available already OR JUST A DAMN TTT DIAGRAM and some good old common sense, you would smack your head and go "OH DUH" and would understand, then be able to brine quench to your hearts content just about any steel you want.
I'll wait to see if anyone is even interested in hearing it before I take the time to type it, or if they just want to talk about adding enough salt to water until you get to the point where you are hardening AND etching your blades at the same time :yawn:
