Yea I heard from another member that he got a s35vn startac umnumzaan yesterday
Attn: rororo64,
Called WC the other day and inquired if they had plans to switch the Startac steel over to S35VN and they said they would keep it S30V- with no plans on change over, anytime soon.
Considering Wilson isn't actually making the Startacs, I can't imagine they have any say in what blade steel is used. It will come with whatever blade steel CRK starts making them in. Whoever told you that very likely just fed you a line of bull.
To the OP... in the lockup photo, I couldn't help but notice the middle one is closing in on the 90% or more lockup. Does this concern you any? Also, since the studs have the polymer o-rings that bump against the handle as a blade stop, does the lockup change depending on how hard you flick open the knife? Does it lock up further if you open it hard due to compression of the o-rings?
I imagine that when CRK changes all of the Umnumzaan blades over to S35VN after the current stock is used up, any new orders from Wilson with fall in line.
To Medic - the lockup on the 'Zaan is different from a Sebenza. The contact point is the ceramic ball at the end of the lock tab. Because the ball is inset into the titanium a bit, the lock tab appears to have greater travel than the lock tab on the Seb. I've been told that even though it "appears" to have further travel, the actual contact point for the tip of the ball against the blade tang is still set at 50-75%.
Can someone post a closeup photo of the ceramic ball that makes contact with the tang? I'm just having trouble picturing how this works, or why it was done over solid lockbar to tang contact like on the Sebenza. Does anybody have or can take anybody take a photo of the lockbar scale removed so I can see the ball that is in the end? Hearing of the knife closing is making me rethink my desire to have one of these knives.
Ok, so I found some images of the detent/lock ball. I can only imagine that Chris was just trying to be unique with this design. Looks to be a form over function thing to me, because you can't argue that the lockbar of the Sebenza just flat out works... Like a vault. I've never heard of a Sebenza closing on someone, and if it has, I'm betting the lockbar tension has been pulled out of spec to make the knife easier to open and close. I do remember seeing a video of an Umnum being used hard, and the guy was able to tap the spine with his finger and get the lock to fail. I do seem to remember reading a followup from CRK that the knife was returned and found to have a lot of pocket lint clogging up something in the lock, preventing it from making full lockup. Not sure, but considering these things are carried in a pocket, pocket lint is to be expected, and should never cause lock failure. Anyway, I guess my concern with the design is, you go from having a large contact area on the blade tang to now a very small contact area. Why intentionally decrease the lock surface area that contacts the blade?? I also know that the ceramic ball on my Sebenzas polishes the area where it contacts the blade during opening. I can only imagine that the same thing is happening to the tang on the Umnum. Maybe I'm overthinking this, but to me, it seems that after the blade is polished enough, it could allow the lock to slip and fail under pressure. Again, this may not be an issue at all, but it's hard to argue that the Umnum does have a history of lock failure on more than one knife (the OP of this thread, and at least one other from those videos). Are there more? I guess I just trust the lockup on a Sebenza more than I trust the lockup on the Umnum, which sucks, because I really like the design, and wanted to purchase one.
Last I heard, the other day when I talked to CRK on the phone it will be a few months before the switch over to S35VN.
Very nice collection! All you need is the Umnumzaan Insingo, and you'll have them all.... Oh wait, I might have dreamed that one up![]()
