- Jun 22, 2006
So I decided to try out some new material (1095 - at least it's new to me). Before I let any blades out of the shop, I decided to do a little testing. I rough ground 5 blades out of 1/8" thick 1095 from admiral steel to about 1/16" thick at the edge (my usual pre-heat treat thickness), drilled and profiled the tang as I usually would. My heat treat method (now, after testing, quite obviously flawed) was as follows:
-edge heated with a torch to non-magnetic (2/3 of the distance from edge to spine)
-immediately water-quenched in a preheated tank (125 degrees F) to hand warm
-transferred immediately from the quench to a preheated temp. oven (400 deg. F)
-tempered for 3 cycles (1 hour per cycle at 400 F, allowed to air cool to room temp between cycles)
Keep in mind that none of these blades cracked in the quench (as far as I could see or hear). Rockwell hardness, according to the charts, should be around Rc 62.
Each of the blades was clamped in the vise approximately 1/3 of the distance from the tip to plunge and pulled by hand (no snipes or torque wrenches here) in the attempt to do a 90 degree bend. I say attempt because not one of the blades went past 45 degrees before snapping like a twig. Here's what I observed:
-3 of the 5 blades broke in multiple places with little or no permanent deformation
-2 of the blades had a brittle longitudinal fracture along the bounderies of the quench line (possible carbide segregation along this line?)
-as you can observe in the macro pic of the cross-section, there is a course structure near the spine (soft area), a finer structure along the edge, and a very fine structure in the center at the boundary of the heated area (quench line)
I must admit I had some apprehension about posting these results, I wouldn't want anyone to think I'm putting out crap - but, I figure that showing the results of my own testing would help a few of the beginners. I have done bend tests like this with O-1 and have not had any issues. This is why I test everything before I send a blade out - I would rather bust a few blades in the shop than ever send out a flawed product.
Obviously, my ht methods on these blades were severly flawed. If Mr. Cashen or anyone else can add anything to help me refine my methods and put out the best blades I possibly can, I would appreciate it.
Have a good one,
Nathan
Have a good one,
Nathan
