BRKT Bravo-2 VS RC-6
Can't go wrong with either one. Both are very high quality knives with solid warranties. That being said I have a Bravo 1 ss and Rat Rc-6 on my short list.
FYI Bark River will usually remove the ramp on the Bravos & Gunny for shipping and handling ($12 when I did it).
Probably do a better job than me.
HERE is a work log on three barkies I have modded.
This is what got me wanting a Bravo II. I wouldn't even mind a Fox River if inexpensive enough.
Both are very good knives.
I have the RC6 and have convexed the edge. It works well in the kitchen and the woods. Takes everything I've been able to throw at it and just keeps on cutting. Battoning is no problem as well. For my bucks I'd choose the RC6.
1. Don't let the convex edge scare you away. If you sharpen by hand chances are you're convexing everything to a certain degree anyway. People are not machines, we don't do perfect angles.
To do a good convex with stones, just grind a back bevel on your back bevel.
2. The Tank Buster is still available on the Busse website. It's probably the most customizable knife they'll ever make, and is right in your size range. I suggest checking it out.
(It should be noted that the Tank Buster weighs just over 18 ounces, and is not a small knife despite it's medium sized blade).
A coated blade has impeded cutting, as well as the possibility of coating getting in your food...
Also, many of my coated 1095s still rust on the edge... A2 is more rust resistant.
A-2 is easy to resharpen and keeps a good edge.
Bark Rivers have much more quality and ergonomic handles...
I would go with the Bark River....
I'm pretty set on a Bravo II, myself.
Tho a Fox River would be considered.
The Bravo II's I've modded were excellent blades. Long enough, thick enough and heavy enough to last several lifetimes. And the A2 Steel was great to work with, and got SCARY sharp.
