This week I got my new BRKT Rogue and after taking it out into the yard yesterday, I thought I write a “short” review.
Intro:
The Rogue is a 7.25” long (blade), 11 oz. (335 g) heavy classical Bowie knife. As such it is obviously a fighter blade, but I was more interested in a woodcraft knife. I have an RD9, which chops very well, but I find it too heavy and long to take on extended trips, while I fear that a typical 4-5” in woodcraft blade has essentially no chopping ability left. So I focused on something in the 7” range that would be a little lighter and more nimble than your average combat blade. The Ratweiler was in contention but its weight (it is about as heavy as the RD9) and the reduced availability took it out of the running. The Rogue is being advertised as suitable for “light chopping and can be batoned through everything that can not be chopped”. It has a leaf shaped blade with a point not too far from the centerline not unlike many traditional woodcraft blades.
Figure 1: Comparison, Buck 119, Rogue, RD9
Initial Observations
Sal Glesser once said that Mike Stuart paid his dues on the grinder…..and it shows. If there is one thing that in my opinion stands out about Barkies, it is the way they are ground. Most of them feature fully three-dimensional blades (meaning they taper and swell in all directions) and there is not a flat spot on the entire knife except for the two facets on the coffin handle. Say what ever you will about the full convex grind, it is the most beautiful and elegant grind there is and the Rogue is a prime example of it. The fit and finish is exceptional. There are only two minor flaws that distinguish this from custom grade: The chamfer on the spine extents slightly further towards the handle on the left (front) side than on the right (back) side, something that is only seen when looking down on the spine of the blade, and the last quarter of an inch of the edge towards the hilt is not fully finished (see Figure 3).
The blade is very well shaped as you can see from the profiles (RD9 in comparison) but it had a small burr on the edge and did not shave. Five strokes (literally) on the Sharpmaker whites and the edge was more than just shaving. However, I noticed a section at the belly that I thought was weak material and a bit of cutting showed this to be correct. The edge in that section turned quickly and became a bit ragged. Therefore I took the blade immediately to a #700 grit stone for maybe 5-7 swipes with very light pressure, removing the edge in that section and then rehoned the entire edge lovingly with a #3000 and #10000. Now, that is pure pleasure! For whatever reasons, the BRKT A2 just takes a beautiful edge, I would still get it goose bump sharp, even if I was blindfolded with one hand tied behind my back (and that is almost no exaggeration!). Part of it is, of course, that there is no reprofiling to be done, all you have to do is to hone the edge.
Figure 2: Profiles of the Rogue and the RD9. The edge angle was estimated with a paper cut, which is not very precise since there is no flat spot on the blade to measure against, but it should be accurate within +/- 1 deg. The RD9 is reprofiled to 15 deg. This figure illustrates what nonsense it is to claim that the convex grind cuts somehow better than a flat grind. But it also shows what a shallow relief a Barkie has, which accounts for its excellent cutting ability. It also shows that at 7 mm (roughly 1/4”
into the cut, the flat grind of the RD9 experiences smaller wedging forces since it actually has a smaller cross section.
Like on my Mini Canadian, the tip came slightly rounded and I used the opportunity to even out the last quarter of the edge close to the handle and to bring the tip to a needle point, both of which are truly minor fixes. So after a bit of TLC I had a 7.25” long straight razor with a needle-point and good, strong material along the entire edge.
To put this into perspective (eventually I will write a review for it as well), my RD9 came with an outright blunt edge that was ground wavy to something well above 20 deg. per side and had one substantial misgrind in the edge. It took about an hour on a #220 stone to straighten out the edge and grind it to 15 deg. per side, and even now I still have a slight recurve in it that requires fixing.
Now, I have read Mike Steward say that the weight of the Rogue is “in the hand” and others saying that it chops better than a 7” blade ought to do. This seemed to be a contradiction to me, especially since the knife is not a very heavy one. Both statements are somewhat exaggerated, but have some truth to them: the key is the weight distribution not the balance of the knife. The knife is balanced right on the hilt, but the weight distribution is very bi-modal: One center of the weight distribution is at the belly, the other is far back at the butt. That makes the balance point very narrow (I would say, less than ½ mm wide). So narrow in fact that it is impossible to balance the knife on your finger, since you finger is too thick to fit right at the edge of the hilt. It is, however, possible to balance it on a thin ruler. The consequence is, that the knife feels quite nimble and not overly blade heavy, while retaining decent shopping ability when choked back a bit.
Figure 3: Balance of the Rogue and the “uneven spine”.
Now, BRKT isn’t exactly famous for their sheaths, but I must say I was impressed with this one. The leather is good quality and I love the look of the rounded hardware. I was very pleasantly surprised. I think this sheath is great. It has a good tight fit with out being too tight on the sides, so you can easily pull the knife out and put it back in without constantly cutting into the leather. In particular I like the feature that the belt loop is removable so that the Rogue can be carried tugged into the belt.
Figure 4: Rogue in sheath.
Intro:
